RickRick
| posted on 1/11/08 at 10:00 PM |
Lighting switches
so what do i need to be able to turn on or off lights wise for the sva test. can all my lights be powered all the time, like the side lights? do i
need headlight flash, or just switch from main to dipped?
| posted on 1/11/08 at 10:13 PM |
Sidelights, main and dipped all independent as the Sierra switches do. Not using the oem gear??
blakep82
| posted on 1/11/08 at 11:06 PM |
are you allowed to have an on-off-on switch for dipped and main beam? of course needing to go past off to switch between dipped and main (but safer
than off-on-on, where you risk switching off altogether)
________________________
| posted on 1/11/08 at 11:56 PM |
Presumably you could have side lights running all the time- otherwise volvos would fail SVA
nitram38
| posted on 2/11/08 at 07:17 AM |
I think the sva manual says that dip/main beam must both be on when you put your main beam switch on.
scudderfish
| posted on 2/11/08 at 08:42 AM |
I thought dipped had to switch off when you put main beam on. They come on again when you flash.
