Hi Guys..
My brake master cylinder is slightly weeping from the pushrod end, so i need to change it pretty quickly lol.
I am having trouble finding the correct replacement though.
The numbers on it are 311834 and k0236.
The unit has 3 outlets - 1x10mm halfway along and 1x10mm and 1x12mm at the end.
There are no pins holding the resevoir on and the is no "bolt head" in the bottom of the unit like I see pictures.
Any help will be appreciated!!!!
Shaun
http://community.rhocar.org/lofiversion/index.php?t12850.html
any good?
