Loads of suspension questions
JohnFol - 11/8/02 at 01:05 PM
Here's the deal. Front suspension is going on. Fitted brackets and wishbones. Set castor and camber to be as correct as I can make it. However I have a few questions I can't get clear direction from
What limits the vertical movement of the suspension? It seems to be the top suspension joint.
When the car is complete, should the lower suspension arm be horizontal?
Top wishbone is angled up on some cars (ie wheel end is highest), and parallel to the lower wishbone on others. Since the vertical movement is limited by the top ball joint, surely having it angled to start with limits the movement even more?
Should the shock absorber be the limiting factor for vertical movement? ie if the suspension moves up from 0cm to 10 cm, should I make sure the bottom extent of the shock travel is 0.5 cm with the upper limit being 9.5cm?
Is there any problem mounting the top shock absorber mount inboard? It is currently positioned upside down, on a welded plate in the triangle you get both sides at the front (sorry, can't remember length names). Particularly interested if this is permitted for the 750 formulae.
Sorry for so many questions, but I guess suspension setup is quite key to a good drive. . .
Alan B - 11/8/02 at 04:03 PM
John,
My build is somewhat different so I can't/won't answer all your questions.
However, suspension travel should be limited by shock absorber travel and NOT anything else. You should be able to remove the shock and manually move the suspension beyond both limits before it binds up on anything (not having your bushing bolts tightened helps when you move the suspension)
Hope that helps a bit.
JohnFol - 11/8/02 at 04:10 PM
Alan, thanks for the response. Are your lower wishbones horizontal?
Alan B - 11/8/02 at 04:21 PM
Yes, pretty much John.
Check out the front end of my rolling chassis in my picture folder in the archives.
interestedparty - 11/8/02 at 04:31 PM
The correct setup for a car with twin wishbone suspension is for the lower wb to be horizontal and the upper to be angled downward from wheel to chassis. This gives more desirable camber change when that wheel is pushed up during hard cornering, the negative camber will be increased more than if the upper wb was horizontal.
John
philgregson - 11/8/02 at 07:19 PM
This is (yet) something else that causes me concern (This user group has been utterly invaluable in my build but I sometimes wonder If I would have been happier in my ignorance just unquestioningly following the book!).
I am about to build my front suspension and I have heard mutterings about the book layout (roll centres etc), which also seemed to be a cause of concern in an article in the recent CCC.
Is the standard book layout crap? or is it just the way some people have built it? Could it be a problem with people increasing wheel and tyre size (I'm planning to stgick with 13x185x60)? does anyone have a better alternative?
Answers on a postcard please.
theconrodkid - 11/8/02 at 08:07 PM
My suspenders are all by the book and it handles like a go kart,i put 185 tyres on and it was crap,im using 155,s again.hth
stephen_gusterson - 11/8/02 at 10:27 PM
as far as my car is concerned, you are bang on right that the top joint is the limiting factor.
although the transit joint is in common use, it actually has quite a small angle of movement as was never a suspension part.
I found that in order to stop it having a problem, I had to angle it. But then I am using sierra type hubs with a 'strut adaptor' in it.
Look at a pic of an MK indy - you will see they had the same problem cos their top joint is also angled.
I was also concerned that a big bump would snap or stress the top joint. however, it seems that people dont do anything to limit suspension travel.
I would think some kinda rubber bump stop on the shocker shaft (if its possible to get one on) would be the way.
atb
steve
philgregson - 12/8/02 at 07:43 AM
I'm glad to hear that the go-cart style handling is present and correct and, to be honest, this is what I hear from most people.
My concern is that some people are quite obviously getting it wrong and I would like to know quite how so that I don't.
interestedparty - 12/8/02 at 07:55 AM
Although the Locost suspension can appear to have problems at full travel, in normal road use the suspension only moves a short distance so it really doesn't matter. The springs are too stiff to allow full suspension movement by such a low weight car.
The springs have to be that stiff because the ride height of a car (assuming you have no way of easily altering its weight)is set by the unfitted length of the spring and its poundage. There isn't room for a really long spring so the springs that are used to set the ride height will also be very stiff.
John
stephen_gusterson - 12/8/02 at 08:00 AM
It seems on my car that there is a degree of adjustment of ride height by altering the spring preload on the shock. Obviously if you use too much preload the shock will be at its bottom stop at rest, which would be a bad thing as there will be no rebound movement.
atb
steve
interestedparty - 12/8/02 at 01:00 PM
atb
steve
Ideally the correct ride height would be achieved by changing the spring itself to one of the required free length and poundage. Naturally the ideal setting would be one where the lower wishbone is horizontal and the suspension in mid-travel. That would leave the spring seat adjustment available for fine adjustments, and more particularly, for setting up the cornerweights
John
Dick Axtell - 12/8/02 at 05:04 PM
Quote:
"The correct setup for a car with twin wishbone suspension is for the lower wb to be horizontal and the upper to be angled downward from wheel to chassis. This gives more desirable camber change when that wheel is pushed up during hard cornering, the negative camber will be increased more than if the upper wb was horizontal." End quote
It also fixes the front roll centre position lower than would be the case with upper w/b angled upwards from upright to chassis mounting. You definitely DON'T want a relatively high roll centre, which would amplify any understeer tendency.
Dick
johnston - 12/8/02 at 07:55 PM
goto amazon and get "compition car suspension" by alan stainforth names spelt wrong but not far away i think!!!!!
got it same time as i got THE book its a good read and explains a lot of previous styles and their pro's and cons
JohnFol - 13/8/02 at 03:49 PM
Thanks for all the comments. I have 1 last question.
The race regs state I cannot change the suspension pickup points. Would these be the points at which the wishbones attach? Does it also include the mounting points for the dampers?
Alan B - 13/8/02 at 04:31 PM
IMO wishbones definitely, and dampers quite likely too.
