does anyone know whether i can put m12 studs into my axle which came with 7/16.
also, has anyone in the oxford or Leamington spa area got an m18 tap i could borrow to clean up my wishbones?
Metric Ford wheel studs fit in place of 7/16" unf studs but seem to remember they are M11 not M12. if you need extra extra long ones Yukspeed
sell them.
As for 18mm threads buy a Sykes-Pickavant spark plug chaser 6 quid even from Halfords -- very handy tool to have also fits 14mm plugs and Lambda
probe bosses.
cheers for the tip on the spark plugs.
i thought there was a slight difference in the studs, but was hoping to just force in the M12 to have the same size on all studs.
If it's any help, I put Sierra studs in my cortina hubs.
Sierra studs are 12mm, if you need longer ones Trackstore sell them for £1.00 each.
Barry.
Be aware that the tap you need is 18mm x 1.5 fine ISTR that spark plugs are 18mm x 1.0.
Chris
Chris![]()
I used one to clean mine last week and are deffo 1.5 pitch. I had to grind some of the nut off in the middle to get the depth but it worked o.k.
