Looking for pics of people steering column placement if anyone can oblige?
[Edited on 10/2/10 by alistairolsen]
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=CIMG0016.JPG
Hope this helps
steering column install
...... Neil
Linky
Linky2
[Edited on 10/2/10 by stevec]
Hi
There is absolutely no good reason for taking the column through the front bulkhead. It gets in the way of you feet and the angle it then produces at
the wheel when placed at a comfortable height means the wheel is all wrong.
Take it over the top of the front bulkhead. Gives the feet more clearance. Puts the wheel at a far better angle to your body. And makes mounting the
front support so much easier.
Just my 2P worth .lol
Cheers Matt
Here's mine
.jpg)
a per matts post, take the steering over the top not under, unless you want to feel like your driving a bus or truck
Originally posted by procomp
Hi
There is absolutely no good reason for taking the column through the front bulkhead. It gets in the way of you feet and the angle it then produces at the wheel when placed at a comfortable height means the wheel is all wrong.
Take it over the top of the front bulkhead. Gives the feet more clearance. Puts the wheel at a far better angle to your body. And makes mounting the front support so much easier.
Cheers Matt
