My Fiat Cinquecento lower wishbones have a built in balljoint. The donor wishbone is too heavy and too short so I need a separate ball joint. The
taper is 1:10 according to figures on the internet, with a 12.6mm wide end aperture. The track rod ends have the right taper but only a 12mm diameter
shank and they're a bit loose.
Does anyone know of a light duty ball joint or male rod end with this taper?
[Edited on 12-6-2010 by smart51]
try ebay for mcgillmotorsports I believe they do rose jointed Balljoints
ring and speak to Quniton Hazells tech dept. May take you a few minutes to get through to the right guys, but man are they good! tell them what you
want and they will point you in the right direction
Quinton Hazel catalogue system is available from here.
http://www9.qha.com/uk/technical/catalogues.htm
Originally posted by theconrodkid
http://81.246.78.74/
For the sake of people doing searches in the future, the Sidem parts database list the BMW E28 (and others) tie rod end as having the same taper. It has an M14 male thread so can be used on suitably equipped wishbones.
I know it's a light vehicle you are building, but have you done the calculations to check if an M14 thread is going to be strong enough? Don't forget the bottom wishbone takes the majority of the load under braking. Are any suspension forces going through it?
The top wishbone takes the suspension forces. The unsprung weight on each front wheel is about 55kg with the driver on board. It is a single seater,
so no passenger.
Total vehicle mass will be approaching 300kg including the driver, possibly plus some luggage. An M14 x 1.5 thread has a nominal area 58% as much as
an M18 x 1.5 (a transit drag link as used in the locost. A 700kg locost with a 75kg driver and passenger on board = 850kg. 58% of that would be 493
kg. My 300kg weight would make 60% of the equivalent load.
It is not a proper calculation but it is less than a proven application. How much more braking force is on the lower wishbone than the upper one?
A nice search on google suggests a bolt in shear has about 60% of its strength in tension. That's about 2260kg to yield for mild steel or about
a 7.5g impact on one wheel. I think a 7.5 times safety factor is OK.
[Edited on 14-6-2010 by smart51]
