Been looking at getting my atlas diff and my gearbox a bit better aligned in attempt to address the vibration i have and noticed that the diff nose if
off set from the centre by about 2-3 inches and just wondered why? Was the original ford engine/gearbox set up not in the middle of the car? i cant
think why else the diff wouldnt be in the centre?
Does it matter if i have the diff and gearbox offset both vertically and horizontally if the angles at each end both match?
So the uj's can work properly
think its just because the half shafts are equal length, which means the crown wheel is slightly off to one side, and so the pinion is off to the
other?
since the crown and pinion are individual items (there's only one of each in the axle) maybe it makes it cheaper to make all half shafts the
same? i guess its more expensive to make them different lengths.
i understand you shouldn't really have a prop perfectly in line as it has asome bad effect on the UJ bearings (so i've heard) maybe it also
ensures the prop is never perfectly in line and perhaps the bearings last longer if thats the case
nope all wrong they did it to reduce noise
thanks chaps, very helpful
Yep, it's a hypoid gear and they're offset in order to be quieter. There's an explanation in CompleteKit Car mag a couple of issues ago.
