Hi All
I'm in the process of fitting MG / Rover alloys to my Clio RS as they are stronger than the chocolate ones fitted (see below) and a lot cheaper
than Renault ones!
The PCD is spot on and the ET is within a mill or two. I've bored the centre out to be the right size for the Renault hub centre.
The only problem I have is that the Renault uses a 12mm bolt and the MG/Rover a 14mm stud or bolt. The plan was to drill and tap the Renault hubs for
the 14mm wheel bolts. However, my mate who was going to do this had gone on hols and I need to sort this quickly! I'm not confident I could drill
and tap the holes without messing them up and I don't have the taps. The hubs are all off and on the bench ready (needed new wheel bearings,
TREs, ball joints and CV gaiters anyway).
Can anybody think of another solution - I did think of sleeved wheel nuts but the sleeve would only be about a mill thick.
Regards
Wyn
Broken wheel
You can get special bolts with slight play between the nut and slieve to allow this. Ask for wobble bolts I think. Bit of a bodge though.
I just spoke to Speedshack who think that provided the seat of the bolt is right, 12mm bolts will be fine. The MG appears to have a 60 degree seat the same as the Clio.
[Non-expert alert]I think that as long as they are a) aligned correctly i.e. centred on the stud/bolt, which they should be if the seat angle is
correct and b) torqued up correctly then you should be OK. (I seem to remember a similar question on here a while ago and the conclusion was
"OK"
. You would need to make sure the wheels are centred before tightening, though personally I would not want to do it on a long term
basis[/Non-expert alert]
Can you get 12mm / 14mm studs? a racecar needs studs instead of bolts anyway...
Thanks guys
12 to 14mm stud adaptors would be the best option but can't find any!
This may be a relatively short term fix as, if I move to a different class for next season, I'll widen the track a bit by using hubcentric
adaptors which I can get made to suit my 12/14mm setup .
Wyn
