sealing split rims
beaver34 - 26/5/12 at 04:30 PM
jsut had my wheel redone and coated just rebuilding them, am i right in think just bolts them up then seal in the groove where all three bits meet?
no need so sealent near bolts or anything like that
IainL - 26/5/12 at 05:04 PM
I used a good quality (Unibond) Silicone sealant on all the mating surfaces.
One did lose air after but this was down to me torquing the bolts up to 15 lb/ft and snapping the heads without knowing
Redone this one and all is fine now.
Hope this helps.
Iainl
JoelP - 26/5/12 at 06:10 PM
i bet a soft non-setting plumbing compound would be fine to seal it, would certainly be easier to take apart! Silicone is phenominally difficult to break when there is a big area stuck.
MikeRJ - 26/5/12 at 10:18 PM
I was going to suggest a non-hardening gasket compound like Hylomar blue. I hate silicone sealer, it's an absolute bugger to remove.
