Clutch pedal size and strength
James - 3/7/12 at 10:50 AM
Posted this thread a few days ago about making a new clutch pedal based on the roadster plans:
http://www.locostbuilders.co.uk/viewthread.php?tid=171857
I couldn't find any plate the size I wanted (5mm) but a mate has given me a piece 6.8mm thick.
I mentioned this to a friend who's an engineer at Mclaren. He laughed at me saying what did I need something that big for? Couldn't I use a bit of box section if I need something cheap? (I do need it cheap! )
When I think about it, he would seem to be right- there's no maths to this but am I really likely to bend a bit of, say, 16gauge 25mm box section (the stuff the chassis is made of?).
And it would certainly seem to be a neater solution than a solid chunk of girder!
How was the clutch so much lighter in the actual Sierra?
Any thoughts?
James
James - 3/7/12 at 10:58 AM
In fact, looking at the OBP cable clutch pedal
http://www.obpltd.com/obp-shop/race-car-pedal-boxes/kit-car-special/cable-clutch
it's much smaller (and most importantly, lighter!)
Right, box section it is then!
James
stevegough - 3/7/12 at 11:07 AM
OY ! are you allowed to post a question, then answer it yourself?
Seems the height of selfishness knows no bounds!
BTW, you avatar pic wot you've had for years is just coming back into vogue.....
Chippy - 3/7/12 at 01:34 PM
Hi James, your question re-Sierra clutch pedal, they are made from very thin steel that is pressed into a "U" shape, so very strog in relation. I have the complete Sierra pedals, shortened, in my car. Cheers Ray
Steve Hignett - 3/7/12 at 01:48 PM
The "corrugated" type shape of the Sierra pedal gives it it's strength as mentioned above, but I'm sure you already knew that.
But in my opinion, I would not rely on the OBP pedal box thinking that this is over-engineered, if I were you...
The clutch pedal doesn't have much force to contend with, but at the same time, it would be a pain in the bum if using 1mm thicker material than you initially thought stopped you being stranded. (I'm obviously exagerating)...
