Hi all,
I'm fitting capri vented discs to my car and wondered what calipers to use.
I was thinking mainly about using Mondeo calipers as they are cheap and powerful.
I know I can used sierra/granada calipers but is there anything else without going to expensive 4 pots. I've heard people recommend using 260
calipers but surely that would be a waist as the pads will over lap the discs by 15mm and not be completely used?
I can make up the brakets to suit but wanted something cheap and easy to find/replace.
Poe.
Peugeot 205 1.6 GTi (bendix) calipers should fit on with a small spacer under the pad carrier. They are mostly ali and weigh about a 3rd what a sierra
caliper weights. I use the non-vented version on my hillclimb/sprint Locost with Mintex M1144s and used the vented version on my 205 with the same
pads and they have been all I ever needed on both. Can be picked up for about £40 a pair.
You definitely don't need anything bigger on a Locost!
P.S. I presume its on cortina uprights?
You can make any caliper fit as long as your disc O/D and thickness are correct.
[img]
Brembo brake upgrade
[/img]
[Edited on 9/7/12 by madteg]
I have been thinking for a while about using Peugeot 206 calipers didn't really think about the older model pugs.
This is all going on to a completely differnt beast!
Poe.
[img]
Brembo brake upgrade [/img]
