Does anyone know the left / right offset for the output flanges on a Ford 7.5" diff (from the input flange centre line).
Cheers!
If I manage to get down the garage tomorrow I'll get some measurements Scootz.
ATB,
Chris
You're a star! Cheers!
From (rusty) memory, isn't the long shaft about 40mm longer than the short one? For both 7 and 7.5" diffs if I recall. So that, if right, would be your answer.
Well if you look at it that way (i.e. read the question properly) then yes
