Hi guys at the point of needing to get some suspension settings sorted are the mag mount camber gauges from sealey or gunson any good or accurate enough?
The magnetic type that are supposed to clamp to the brake disc are pretty useless you have to be able measure the camber with the car sitting on its' wheels in the normally loaded condition ---- much cheaper get a digital clinometer or digital spirit level off ebay. You can even use an ordinary spirit level with a bit of ingenuity and some trigonometry.
I ALIGN app for smart phone works well , set my rear beam on a jig to 1.4 deg neg and the phone read exactly the same . it measures caster too and
was .4 degrees out on my car
