I have been looking for the specs for all the wishbones so I can model them up and put them into the CAD assembly that I am busy with, but cannot find
any info anywhere.
Is there anyone prepared to help me with this, please? I need dimensions and mounting points on the chassis, if possible.
Many thanks,
Tony
Haynes Roadster book is a good start
I have drawn up the McSorley 442E chassis so far.
Fantastic, that is perfect, thanks very much.
You want the 2nd Edition Locost book then- as advertised on the front of this site.![]()
Or here: http://www.amazon.co.uk/exec/obidos/ASIN/1859606369/locostbuilder-21
James
[Edited on 23/10/12 by James]
Tony, I have sent a U2U.
James
If he is building a larger lotus 7 variant wouldn't the Haynes Roadster be a better match for the Mcsorley 442 chassis, sorry if I have got this wrong
James,
I believe we both did the same, i.e. added 4" to the centre of the car, so the whole car is wider.
I also believe that the 4-4-2, though wider in the body, uses a standard nose.
I therefore deduce that the engine bay must narrow more and that wish bones and their mounts
may not be the same.
Could be wrong, and frequently am.
Paul G
