Hello,
Ideally I need some 80 x 60 x 3mm mild steel box section if it exists, can't find any on google, but I'm sure in the past I have found some
on line somewhere
Any pointers?
Have to be exactly those dims?
Get some folded at your local fabricators.
They could fold you a box but you (or they) would have to weld the joint.
De Dion?? Seriously? Is this 1939?
Strangely enough, in the UK, the only way to get 80 x 60 RHS is in stainless steel but in hot rolled carbon or ERW the nearest you'll get is 80 x 40. If it is only a short length then I would suggest a pair of 77 x 57 pressed angles, open corner welded would come out at 80 x 60. As far as I'm aware, it is not possible to press 4 sides of such a small box section so I think that option may be ruled out.
Thanks everyone for your help, I will section a 80 x 80 x 3 box section I already have, it's only a couple of short runs I need, so not to
differcult to achieve
