Where to source custom hardened pins?
cloudy - 6/11/12 at 12:04 AM
Am repairing a quaife diff, and need to replace 8 pins approx 6mm diameter 30mm length, but they need to be hardened steel - any ideas where I might find such a thing?
James
blakep82 - 6/11/12 at 12:09 AM
quaife?
Alan B - 6/11/12 at 02:47 AM
How about dowels?......of course they would need to be a standard size like 6mm or 1/4"
snapper - 6/11/12 at 06:06 AM
They will be hardened to a specific Rockwell hardness I suspect,
liam.mccaffrey - 6/11/12 at 07:20 AM
M2 M3 M4 M5 M6 Dowel Pins Hardened and Ground Steel Dowel Pins Packs of 4 or 10 Possible?
cloudy - 6/11/12 at 07:24 AM
Dowel pins are what I need! Thanks, will try quaife but they usually wont sell spares...
James
hughpinder - 6/11/12 at 08:38 AM
rs sell some sizes:
http://uk.rs-online.com/web/p/dowel-pins/0270653/
Regards
Hugh
jon200 - 6/11/12 at 09:17 AM
Dowel pins aren't always hard, especially RS ones. Unless it specifically says they are. RS are good but can be pretty basic when it comes to these things. I can harden 416 stainless if needed in a vacuum hardening machine at work. We may even have 6mm bar but I don't know what tolerance it is. I'd have to check what Rockwell reading bits too though.
Alan B - 6/11/12 at 11:07 AM
Agreed dowel pins in general aren't always hard...but hardened dowel pins always are... Those are usually made from a tough steel then case hardened and precision ground to a very close tolerance.
jon200 - 6/11/12 at 12:20 PM
I was just pointing out that a dowel may be soft and not necessarily hard that all.
hughpinder - 6/11/12 at 12:22 PM
Just checked up - it seems RS ones under 4mm are 'soft' and 4mm+ are case hardened. I newver realised that!
Hugh
Alan B - 6/11/12 at 12:23 PM
I know, and it was a good point.........it was just a tongue in cheek response by me......
