given enough height, is it possible to remove a sierra diff from its rear subframe/tube, without pulling a driveshaft/ wheel bearing carrier ?
want to do it indoors, but the garage is a bit tight....
yes, the whole rear beam comes off in one:
the long bolts at the front/sides of the beam can be a pain (the ones that go thought the big rubber mounts)
other than them its just the propshaft, diff mount, dampers and brake lines/cables
if your going to lift it up high to do the job don't forget to use something to catch the beam - its heavy !!!
mind you I cheated a bit with that one
http://i5.photobucket.com/albums/y170/mcerd1/Donor/Image002.jpg
[Edited on 16/5/2013 by mcerd1]
Bolt on or push-in driveshafts?
I think with bolt on, it should be possible.
I removed the whole subframe (as above) although I didn't have a tractor so it was a bit more scary towards the end.
push in shafts, hoping to get diff out of car/beam without taking the hubs off.....
If you were just after the diff.....
I cut one out with a 12" grinder
no, i want to swap diffs!
