Hello All,
Just failed IVA on brake bias and its been suggested that I try 19mm diameter rear cylinder to reduce the braking force.
I'm on sierra rear drums.
Does anyone know where to get them or what model to order.
I've seen some 19mm transit cylinders will these fit?
Thanks Paul
Check with your local Ford dealer but I'm pretty sure that the Ford Cortina had 19mm wheel cylinders and I'm also pretty sure they will fit your Sierra brakes.
You will need to identify which rear brakes you have fitted first, Ford used brakes from different manufactures.
The Brakes International online shop gives info on cylinder bores.
Thanks for that.
I'll go to Rochdale, Brakes International on Saturday morning and get sorted out.
The Cortina has 19mm or 17.8mm cylinders which will do the job.
Paul
19.05mm
Brake engineering WC4918 Wheel Brake Cylinder, use that at most motor factors and they should be able to cross reference to other makes
Adrian
You cant be that far away if your going to Rochdale
Originally posted by AdrianH
19.05mm
Adrian
