Tried doing a search with no luck. Anyone have any idea what thread the maxi ball joint is?
Regards, Ian.
Hi Ian,
Are you after a couple of nuts for Maxi balljoints.
I may have a coupl eif you are.
let me know,
Kelvin
UNF -- don't know the dia but it suspect 1/2" or 9/16"
Mine too
It may depend on who makes the ball joint, I found this with Escort TREs, the originals were 10mm fine but replacement ones were 10mm coarse, so
depending on the manufacturer they may well be different. If you need to know what yours are, invest in a set of thread pitch gauges, they're not
expensive, you can get them to do both metric & imperial & they`re hugely useful, save a lot of stuffing around & guesswork. Cheers,
Steve.
[Edited on 16/12/04 by Steve Hnz]
Quinton Hazell Maxi BJs are 1/2 x 20 UNF Class 2A.
I suspect many imported pattern BJs will be metric.
New nuts are nearly always supplied with balljoints though, or have you mispalced them?
