My Fury failed it's MOT on knackered bushes so I'm having a crack at replacing them all. I thought I'd start with the ones in the
shocks (Spax M73) and bought a pair of bushes from Superflex. They were too long, but the right OD. I cut them down to size. My problem is that the
installation instructions say install the bush (done that) and then install the crush tube. However, pushing the crush tube into the bush eventually
just pushes the bush out of the shock. I can't get the bush to remain in place as I pass the tube through it. Any hints? I've got a
press, but I've been finding a vice marginally more controllable.
Regards,
Can you use a bolt + nut, with appropriate washers, to pull the tube into the bush? Might benefit having plenty of soapy water to lubricate?
Success! I 3D printed a solid hollow cylinder that would allow the crush tube to pass, but not the bush. A bit of wiggling to and fro with the vice and I now have a centred bush with the crush tube just slightly proud of it on both sides. Now to do the other 9......
The crush tubes really shouldn't be that tight a fit in the Bush that they'd push the bush out. Tight enough that you can just push them through by hand really. The risk is either the Bush twists in the outer rather than on the tube; or it puts a bending force into the outer (and whatever its attached to) and that eventually gives in to metal fatigue.
