I've got a diff fitted in the car ar the moment (non LSD). If I pull the drive shafts out will it wee oil out (its set to proper fill level)?
I reckon so
another of my really stupid replies!
Can't remember, even though I drive a Sierra, but if the filler/level plug is below the driveshaft level then yes, if not then no.............to
state the obvious! (so not much help unfortunately!)
It did when I took mine off.
Yes, but not much as the oil level should be slightly below the lip.
But seen as you can get the diff out with one hand, you can hold a tray with the other!
Pat...
diff out with one hand?
bloody hell pat, you must have arms like mr t
or should that be halfshaft(just read the bulk of the thread again)
tom
(oil level should be 10mm below filler plug if set to "correct" level)
[Edited on 8/2/05 by indykid]
