Anyone know if the description on these is correct? It says that they will fit Cortina 3, 4 and 5 as well as the Lotus ones. Std cortina discs are
247mm dia, those are 245mm.
The same discs (247mm) fit the Mk2 escort (not Mexico etc).
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4553086426
Help...
look at qha.com (quinten hazle cataloug,all fitments/dims on there
Forgot about them, ta John. The discs are slightly smaller...
Gah...will just get my bid cancelled on it. And tell him i dont think the description is right. Grrr
have a look at this website i got mine from their it gives sizes for all discs on cortinas and escorts i think most of them were the same size apart
from the mexico
https://www.sapmotorparts.com/shop/english/
hope this helps
Antony
[Edited on 31/5/05 by antonyg]
Quinton Hazel list the discs for the cortinas and escorts and capris as different. They are at least different in diameters, 245 vs 248mm.
I'll just stick with normal discs now anyway.
Cheers.
Here is the cheapest place to buy Cortina MK3 to Mk5 discs --- the MK3-5 was totally different ftom the Mk1 & 2 with Lotus/1600e/Corsair models
being different again.
https://sslrelay.com/buypartsby.co.uk/discs_details.php?recordID=2023
[Edited on 31/5/05 by britishtrident]
Cheers BT. You confirmed what I thought. I got the guy to cancel my bid on Ebay, though he hasnt modified the description.
Do the discs from that site work out cheaper than buying them from a motorfactors, by the time you add postage etc? Works out at £22.58...
[Edited on 31/5/05 by flak monkey]
I looked at his picture of the box they are actually the discs that were fitted to the Ford Corsair and adopted for the Cortina Lotus -- later
fitted to the MK2 1600e the RS Escorts and some UK built Capris.
Mind you a 1982 Cortina Lotus would be worth a bob or two -- they stopped making them in 1969
