Thank in advance,
I have a set off 20 wishbone eye sets from Robin Hood, the bushes are made from what looks like very tough plastic it is not like the deflex softer
yellow bushes you see.
Are these rock hard bushes suitable for the 4 trailing arms ends for an axle bearing in mind the twisting that will take place on corning
If not any suggestions on replacements and supply?
They are what I used David.
Bob
Originally posted by Minicooper
Thank in advance,
I have a set off 20 wishbone eye sets from Robin Hood, the bushes are made from what looks like very tough plastic it is not like the deflex softer yellow bushes you see.
Thanks for the replys Bob Mike,
Mike
I was thinking the same, although my mounts are 3mm including the support, but I'm still concerned, I'm gonna go with it since I have them,
I will manually try and deflect the axle, if its rock solid I will change the bushes for something more forgiving
There are bushes and then there are bushes!
The important factor to know is grade of polyurethane and shore hardness. I have heard of some bushes supplied that are more at home as anti-vibration
machine mounts rather than for automotive sports applications. 'Testing' at home is to a large extent a waste of time as you cannot really
apply the same forces to test torsional rigidity that are applied in practice. Some of the lesser grades will seem fine at first but may suffer in the
durability stakes over time. It is the cheaper types that tend to give the secondary problem of unwanted noise.
My recommendation - buy what can be proven to be correct for your application.
Darren Cheers for the reply
I'm concerned about the bushes this is why I have posted. There must be loads of trailing arms out there on various live axle cars.
A fair amount of people must know what works well, I was hoping for a reply from one of these people with the car on the road working well with little
noise transfer and great axle location control
PS I also have the metalastic bushes from the Herald would these be more suitable
