I know this has been discussed before and that the hub to disc bolts require lock tabs (Cortina) but I was watching an MG is born or re-born or
whatever on Discovery and shaw Evans use lock tabs on his calipers.
Does any one know if this is required?
Richyo
i think they are. As ford would not put them on for nothing mine were allrady on there when i got mine so i think you should put some on hope it helps
Mine were so corroded they just looked like washers
Ford used them on the Cortina, Vauxhall/Opel never did on the chevette/manta/ascona/cavalier/monza/mk1 senator/commodore/rekord etc etc etc all of
which used the same tye of setup as the cortina........................................................who was "right"?
Discs and calipers never seemed to fall off either car!!
