Brake pipes - right angled connection / banjo.
lsdweb - 25/10/05 at 12:34 PM
hi All
I've just fitted rear calipers (see separate threads) and the brake hose entry to one of the calipers is pretty close to the panhard rod mounting. I can get acopper pipe with a bend in no problem, but I'd like to use the braided hoses I have directly into the caliper. The fitting is metric (8mm).
Does anybody do an 8mm banjo fitting - I've found loads of 10mm but can't find anybody doing 8?
Regards
Wyn
JAG - 25/10/05 at 12:53 PM
Are you sure it's 8mm pipe thread??
10mm is much more common.
zzrpowerd-locost - 25/10/05 at 01:05 PM
Goodridge do straight 8mm ones, maybe ask them bout 90 degree ones
Do stuff thats not in catalogue
lsdweb - 25/10/05 at 02:22 PM
I'm confused!
They're definitely not 8mm! Closer to 10mm. Possibly 3/8" UNF but I don't think so! How do I check? None of my measurements are helping! As the calipers are Peugeot, I'd guess they are metric?
Wyn
NS Dev - 25/10/05 at 02:55 PM
surely should be M10 x 1??
.............unless the French have done a corker and used M9 fine!! te hee!!
They use M7 for bleed nipples, but then so do a few others too!
[Edited on 25/10/05 by NS Dev]
rusty nuts - 25/10/05 at 05:30 PM
As NS Dev says likely to be 10mm. x 1 . Cant say thet I've ever come across an 8mm pipe nut except on perhaps Citroen systems
bob - 25/10/05 at 05:51 PM
I had my rear braided pipes with banjo ends at caliper made up by thinkautomotive in isleworth middlesex,worth giving them a call when you find out the thread size to see if they can help.
http://www.thinkauto.com
I think they were £10 each
Mention the site for possible discount
lsdweb - 27/10/05 at 08:42 PM
Thanks All
Definitely 10mm X 1
I was having yet another senior moment!
Wyn
