Steering Rack Locknuts
jambojeef - 6/1/06 at 12:55 AM
Mk2 Escort rack locking collar things.
Where on earth do you get those from???!!!
Geoff
02GF74 - 6/1/06 at 08:46 AM
if you knew the diameter/thread then maybe a half nut would do? Dunno where you get on ofthose from.
flak monkey - 6/1/06 at 09:05 AM
Geoff
You'll be lucky to get any from anywhere!
Why do you need them anyway?
britishtrident - 6/1/06 at 09:49 AM
Of a Mk3 Escort rack -- same manufacturer
jambojeef - 6/1/06 at 01:46 PM
I have replaced by Mk2 rack with a quick rack kit but had to cut one of the locking rings off the old rack so need the locknut/collar to make sure I still have steering past the end of the street!
I guess I could lockwire it?
I have tried Ford's and a few bolts and nut stockists but with no joy - think I even tried to buy a tap with no luck either!
Do Mk3 escort rack locknuts actually fit then BT?
Geoff
britishtrident - 6/1/06 at 02:14 PM
If you look at the book you will see it is just a rear steer rack made from the the same parts.
Usually Brit manufacturers had 2 suppliers with istr Ford was mainly Burman racks
02GF74 - 6/1/06 at 02:24 PM
I would guess not!! Not sure what Mr. MOT would say either.
Not really know much about lock wire but isn;t the nut already done up to spec and the wire is a secondary measure? in your case there will be no nut.
If you can find out the thread/diameter then that would make it easier?
martthefridgeman - 6/1/06 at 06:03 PM
should be m14 half nuts you need. i got mine from ahc nut and bolt supplies in camberley surrey. MJA
DanP - 6/1/06 at 06:59 PM
I've got a billion of these (M14 halfnuts) as i had to order a minimum quantity of 36 when i only needed 2 - give me an address and I'll bung a pair in th post if you like
jambojeef - 7/1/06 at 01:28 AM
Oh wow!
Thanks!
You have u2u
Geoff
flak monkey - 7/1/06 at 10:41 AM
Umm, i dont think the TRE locknuts are what you need, ae they?
They are easy to get hold of from any hardware place.
I thought you meant you needed the locking ring which locks the track rod housing onto the rack itself?
