Can someone put my worries to rest on this one?
Finally got my rear axle (from an RS2000) and have started cleaning it up however it now looks like the trailing arms are going to be very close to
the inside edge of the tyres/rims. By close I mean less than 10mm either side. Is this normal or have I messed something up?? It's difficult to see
exactly how close they are in the pictures in 'the book'.
Also, if they rub, can I get wheel spacers or will that mess the suspension angles up?
Cheers!
Chris
Can't see that you have got it wrong as the forward rear brackets (on the chassis) can't be welded anywhere but right. You could fit spacers to clear
the arms, you may only need a shim! It shouldn't change any angles as you are only bringing the wheels out parallel.
If you need spacers between 1mm and 12mm let me know your PCD and i'll laser cut you some!
I couldn't see where I could have gone wrong either but my moutings for the forward rear brackets are slightly different to the book! The centre of
my mounts are 1065mm apart which leaves about 50mm each end of the axle between the bracket and the back of the drum.
On the subject of wheel spacers - how much hassle is it for you? May well be interested for my XR2000! I'm a bit worried the SuperT's will look too
small once I get my new arches on it...!
ChrisW
No problem, just give me your PCD and tell me how thick you want them and they will be done! (after Christmas now!).
Excellent! Once I've got the arches on I'll get in touch (which will be after Xmas now!)
Chris
If you want standard arches I will have a pair for sale after christmas (as in the photo's submitted to you) will be about £40 quid if you are interrested? reason - I have a cortina axle which is about 6" wider!!!
Thanks for the offer! However I was talking about one of my other cars. Somehow I don't think Locost arches would fit on it!
Chris
why not! be different!
...on this?? There's being different, and there's being different!
Chris
Is that your donor car Chris?
Nice wheels, would look great on any Locost.
LOL
Pablo
but Chris. it's got a roof! and a windscreen! and a heater! and doors!
What is wrong with you???
...but it's also got 158bhp at the wheels and with the speed it's capable of things like windscreens become more of a necessity!
As for it being my donor car... the amount of ca$h i've spent on that will probably treble my Locost's budget before I'd even started!
Chris
Chris are you of SpeedCentral fame? Car looks familiar
