anyone got any pics of a sierra column i can have a look at. just recieved one at the weekend and want to check a coupld of bits:
1. the connectors/bushes for the horn seem to have abit missing as they are just hanging down off thier springs at the moment
2. should the triangular profile of the column be tacked to the tubular part of the column (the collapsable bits)
cheers
Ian
there should be a plastic guide for the springs
From memory, the end of the tubular piece is formed into a triangle and has a plastic insert. The triangular piece is pressed into this. The two
pieces are not tacked together.
It's just visible in this photo.
Maybe this will help you
thanks for the help guys, its made things abiy clearer
don't suppose anyone has the plastic guide for the springs going spare?
cheers
Ian
