Hi all sorry prob a daft question u have been asked b4 but does anyone know if the mt75 fits straight onto the pinto
Been offered a 2.0i DOHC with disc rears
The cat supposed to use drums a pinto n a type 9 so couldnt be gettin further away from their book spec
Never dealt with the mt box any help would be appreciated
Paul
I dont know for sure BUT. I dont think that you will get the MT75 in a Tiger chassis ?
Bell housing bolts are the same but you will need a spacer on the thrust bearing as the clutch on the Dohc is very deep. 19-20mm as per the westfield
item.
The best match for your pinto is the type 9. All nice and easy of the shelf bits.
just my opinion
mmmmmmmmm may need to rework the chassis then
Pinto does bolt onto a MT75, no problem. Rubbish picture in my archive
here
The sheetmetal plate between them needs a bit of trimming, and you can trim a little off the bottom of the bell housing.
The clutch release bearing may need a spacer, like the Westfield do (but I've also been told that a DOHC clutch is deeper and lets you use the
standard release bearing, I'll be trying this soon)
Thanks guys
the tiger trans opening is angled unlike rons book chassis what are your measuments on yours John not that i dibeleive what bigwasa said but i gotta
try to see if i can use this car as struggling to get any thing else and this is holding me up i have a pinto engine from when i raced but the gearbox
is a straight cut not much use on the road also think one of the gears locked off
Paul
HI AS you used to race youl prob find the ratios in a mt75 a bit to wide spread . Where as with a type 9 you can pick up a box with close ratios for
little money or if you have a straight cut box that requires a bit of work a direct swap would be in order i would think. Just a thought.
ps with a (heavy) engine you could do with a lighter g/box
cheers matt
Cheers matt
gearbox isnt the great issue its the rear axle set i desperatley need for aligning body work blah blah as they are disc on this car should be drum on
the cat but i can modify the system no prob just that it has an mt 75 box was just trying to use parts may buy the car anyway to sit in corner for
next build (gonna finish the chassis i started 3years ago
Your inputs are much appreciated seems i have hit lucky on this site great bunch of guys
chers Paul
