steering rack mounts
brianm - 17/5/03 at 09:22 PM
The chassis of my lowcost (bought as an abandoned project), is supposed to have been built by someone who has built book chassis before; (all the errors in the book seem to have been avoided/corrected), but the steering rack mount centres are only 185mm apart. It came fitted with a recon. Escort rack, which gives fantastic steering lock in one direction, but severly limited in the other. Can anyone think of a reason why they should have been made so close, instead of the 260mm apart that I think they should be? Intended to be used with a different rack? Different kind of clamp intended? Simple mistake? All other chassis dimensions are exactly as book.
Mark Allanson - 17/5/03 at 10:15 PM
Any chance of an image to claify your problem?
If you have different lock on O/S & N/S, the rack is not central, perhaps the chassis was intended for a different rack?
