WHAT INVOLVED IN TAKING THE SERVO OFF AND DO I NEED IT
break servo?
some people seem to fit one. ok if you have the space.
If the servo gave 2:1 assistance & the car was 1/2 the weight, then not having the servo would result in the same weight pedal but with a bit less
lost motion.
I think servos are usually 2.5 or 3 : 1 and the car's a bit more than 1/2 the weight so you end up having to press a bit harder
Bob
Originally posted by Bob C
If the servo gave 2:1 assistance & the car was 1/2 the weight, then not having the servo would result in the same weight pedal but with a bit less lost motion.
Bob
break servo?
It the servo from the sierra, i have used the sierra pedals. I could fit the servo but do i need it.
No , you dont need it. Just fit softer pad's.
