hi all has anybody got a diagram of the spring set up in the rear axle as i am ready to reassemble but got no idea where they all go i didnt strip it
so i couldnt take note of where all the spring and things go
thanx in advance
colin
Do you mean the suspension springs Or the brake drum pull off springs etc????
Take a look at Page 4 of my website (link below) for this pic and others
I am guess you mean the springs for the brakes; here is the mk2 escort back plate correctly assembled, drivers side. The wheel cylinder is on
the top.
I did take a photo prior to taking it all apart to avoid the problem you are facing!!
rear brake
cheers roadkill spot on mate
thanks
col
thanks o2gf74 that is a great detailed picture helps me alot many thanx to you
cheers
colin
