Trailing arms & Rose joint's
ecosse - 27/2/07 at 07:46 PM
Can anyone confirm whether 10mm rose joints on my trailing arms would do the job, or should I be going for something a bit bigger?
Alex
PS
This is only on one side, the other will be the usual bushed affair
JoelP - 27/2/07 at 07:52 PM
i would be happy with that on my car, others might suggest bigger. More depends on the quality of the joints though i believe.
Peteff - 27/2/07 at 07:52 PM
Or one end, depending where you are looking from I used M12 on mine but M10 should be well up to the job if they are decent joints. My logic was most motorsport applications use 1/2" and M12 is nearly there.
ecosse - 27/2/07 at 08:18 PM
I was looking at CCVI joints pos type, steel/bronze with lubrication points
"The Basic load rating is 20.61 (kN)"
(no idea whether that is good or bad!)
The axle is sierra DeDion if that makes a difference, I suppose as it's lighter than a live axle it should? Or is that statement asking for trouble
Alex
RazMan - 27/2/07 at 08:27 PM
M12 was my choice - plenty strong enough
russbost - 27/2/07 at 10:31 PM
Mine are 5/16 or 3/8 can't remember which for sure, they are originally from a Formula Ford 2000 so they obviously felt they were up to the job, I'm putting roughly double the horsepower thro' them with no probs. I would point out tho' that most metric rosejoints are aimed at lower quality end of the market, top quality ones are available but not easy (or cheap) to find.
procomp - 28/2/07 at 08:39 AM
Hi you will find that by using a unf thread you will be able to have a much finer thread/adjustment per half turn of a joint. As apposed to a metric thread.
cheers matt
ecosse - 1/3/07 at 04:13 PM
5/16 or 3/8 for the trailing arms?
So 7/16 rather than 10mm ones would be plenty, presuming good quality ones are used?
Good point Matt, as above, 7/16 in UNF should do the job then?
Am I right in thinking PTFE lined ones would be prefered over steel or brass?
Alex
