The car is well and truly back on its wheels now with rebuild all but complete........
The rear end !! ?
Nothing as changed, had axle out, changed a bearing and brakes, same springs, shocks etc but it now sits a good inch higher on re fitting ?
No amount of bouncing etc seems too make it want too "sit down" will it bed in ? Anyone else had this ? I'm seriously thinking I may
have too obtain shorter springs ?
Odd, very odd.
Strange????
Presumably you've left all the final tightening of any bush bolts until the cars weight is on it's wheels???
sorry if I'm stating the pbvious.
hi jon did you do the tightening up with the wheels off the floor, may just need driveing round to settle everything back into its normal position. or
if you can do it slacken and retighten the suspension bolts with the cars wieght on the wheels .
damm my slow one finger typeing
[Edited on 11/3/07 by bigrich]
Derrrrrrrrrrrrrrrr
You two have probably hit the nail on the head.
Thanks for stating the obvious.
