I've moved my engine quite far back and because the box is quite long the gearstick is right where the handbrake wants to go. I can't really
(read as don't want to
)move it back as there's a metal bar in the way.
does anyone know if there are "shorter" levers out there from another car.
The one I use - Toyota MR2 Mk1 is pretty small, can get you some dimensions if you want?
if it's the sierra handbrake handle you have, I shortened mine, did'nt take long to do and looks alot better than standard.
link to tutorial below:
http://www.stevenbiddulph.com/stevenbiddulph.com/Hammerhead/projectshandbrake.htm
Rover SD1
cheers
Chris
Metro aint bad either.
Pat...
nice little job!!!
cheers,
Steve.
glad you like it worX. Cheers.
another metro handbrake here
I'm with Russ. MR2 - mounts to side of tunnel, similar to Midget.
Looks good steve.
any pics of the MR2 or Metro ones guys.
Yeah I don't like mine as my arm hits it when I hold the gearlever. Now I know what to look for, ta
I shortened mine differently.
I removed the button mechanism then cut off the lever at the ridge near the button end (about an inch off). then made a new ledge for the mechanism by
using a ring of blind rivets. reasembled it and bent the rod to suit. I found i had to drill out th hinge pin and replace it with a nut/bolt
though.
works well and no welding involved
Here we are:-
[img]http://[/img]
Gear stick where the handbrake is? Thats a bit extreme is it not? changing gear with your elbow??
Originally posted by coozer
Gear stick where the handbrake is? Thats a bit extreme is it not? changing gear with your elbow??![]()
if i put the handbrake in the std place the button would be 2" past the centre line of the gear stick.
be careful if you use my method. Cut too far and you will cut through the pushrod.
Best to use a dremel or if you are feeling energetic, a hacksaw. Good luck.
midget one,nice chrome and fits on the side,think i have a spare one if you want one
I have a lotus elan umbrella type under my dash, its been a bit of a PITA making the mechanism for it and I won't know how well it works for a
wek or two but at least nothing to bash my elbow on!
Caber
