Hi Chaps,
Does anyone know if it is possible to remove the arm that activates the handbrake on the sierra rear calipers? I could just cut it off but if I can
take it apart in a way that could be put back together later that would be better!
Ta, James
pretty sure you can disassemble, there is a precedure in the haynes manual.
Yes, I think it could be done, I had it out when i did my calipers to replace the seals. The shaft that connects the handbrake lever to the piston
would need to remain in place as it has an 'O' ring in place which seals the back of the caliper.
Hope this helps.
