Redrilling OZ Super/Ultra Legera's
JimSpencer - 30/4/07 at 09:52 PM
Hi All
Decided that I need some lighter rims, have to use 15's to get the right tyres (MSA list 1A hillclimbs & Sprints)
Without spending silly money the lightest I've come across are OZ Ultra Leggera's at 5.1kgs each - which is good.
But
Using on a Striker so 108pcd rear / 100 front.
OZ alloys are ET25 for the 108's which is good and ET37 for the 100's which isn't..
So anybody got any thoughts on Making a set of 108's 'Multifit' by having them drilled?
Anybody done it?
Anybody got any they can have a shufty at and come back with an opinion?
Or best of all anybody recommend a similar weight 1 piece alloy (i.e. cheap) that's available in the right size so I don't have to bother..
Thanks all
gazza285 - 30/4/07 at 09:56 PM
What's wrong with using a spacer?
R1 STRIKER - 30/4/07 at 10:25 PM
OZ spacers are pretty good and have a locating ring on them. What front uprights are you using? Is changing them an option?
Ben.
Jon Ison - 30/4/07 at 10:28 PM
Don't know about hillclimbs n sprints but scrutineers don't like spacers on tarmac circuit racing ?
I would check it out before you go down that route.
How about drilling your hubs too suit ?, 1 size fits all ? Done properly marked out on a lathe pretty easy job.
[Edited on 30/4/07 by Jon Ison]
MikeRJ - 1/5/07 at 09:51 AM
That's the best idea IMO, saves loads of hassles with different wheels and no nasty spacers/longer studs to worry about.
JimSpencer - 2/5/07 at 10:24 AM
Thanks All
Very good point, hadn't thought of attacking the problem from the other direction..doh!
Sounds like a much better idea to me..
Doug68 - 2/5/07 at 01:18 PM
You want to drill holes in these? you should be ashamed of yourself
