Sierra steering column
neilj37 - 25/5/07 at 09:22 PM
This is probably a really stupid question but how do you get the cowling off a sierra steering column. I have undone the 3 screws underneath but it still won't come off and I can't see anything else to undo. I don't want to force it for fear of breaking something. I just need access to the ignition cables.
jos - 25/5/07 at 09:23 PM
have you taken the steering wheel off too?
bob - 25/5/07 at 09:25 PM
There is also a screw in the top next the hazard switch, the two halves do click together but once all the screws are out it should rattle about and part.
Hellfire - 25/5/07 at 09:34 PM
If you've removed the three screws (two on the bonnet release catch and one at the front) just give it a wiggle and it should pull off. The top half of the cowl can be left in place, as can the steering wheel.
Phil
neilj37 - 28/5/07 at 09:25 AM
Got it sorted. The 2 bolts for the redundant bonnet release were holding the cowling on.....doh
