Oil in CV joint
40inches - 2/7/07 at 12:09 PM
Got a couple of drive shafts(push in) from a '86 Sierra 2litre, when I pulled back CV boot, oil poured onto workbench so I got another pair from a '89 diesel. They are oil filled as well. Did Ford use EP oil instead of grease on some year models or have I just been unlucky? twice! Would CV joints be OK running in EP oil instead of grease?
stevec - 2/7/07 at 12:38 PM
I have seen the grease in these joints turn to liquid but have never seen an oil filled one.
Steve.
iank - 2/7/07 at 12:42 PM
The grease in the mini CV's I got poured out as a thick black liquid. Horrible stuff to clean up as well
worX - 2/7/07 at 01:39 PM
I'm pretty sure it won't be oil, but the grease thinned out so much.
Just check everything as you would normally and then refit with new covers and grease as normal - "sould" be OK!
40inches - 2/7/07 at 02:41 PM
Thanks for that, looks and smells like EP90, as said, new boots and regrease I think
