This may sound daft, but i have a radiator from a renault and if i fit it nomally the out- let would stick out slightly from the nose cone as its a
book built chassis. Can i turn the radiator or would this effect the flow.
Or should i stick to my escort one?
The outlet is at the bottom of the radiator. Not shure what you are asking, can you explain connections for this dumbo?
It has an in-let at the top left looking from the back and out-let at the botom, what i was after can i turn it so the in-let and out-let are on the top left and right tilted on a 20 deg angle.
no
