diff out put shafts-removal
gr8ging - 25/7/07 at 07:35 PM
As per title, how do I do it?
I have a sierra 3.62 LSD bolt on drive shafts. And I want to remove the out put shafts from the diff to clean and paint them. Do I have to tack the back cover off the diff?
robinj66 - 25/7/07 at 07:38 PM
As far as I'm aware, you just undo the bolts (allen key) that hold the CV joint to the diff and remove the whole lot (at least that's what i did on my Mk II Granada). Might take a bang or two with a mallet once the bolts are out.
mookaloid - 25/7/07 at 07:42 PM
Yes you do. There are circlips to remove so that you can then remove the flanges.
HTH
Mark
BenB - 26/7/07 at 08:31 AM
If they're bolt on @ both ends (ie Lobro) then you just undo the bolts @ both ends and (if necessary) give the driveshaft a gentle tap with a mallet... You shouldn't need to do anything to the diff....
Remember to use threadlock on the bolts afterwards (and degrease the Lobro bolts first if you're going to re-use them)!!! Diff bolts coming out is not nice!!
gr8ging - 26/7/07 at 08:38 AM
I want to take the outpit shafts/flanges out of the diff, not remove the drive shafts as I don't have any I just have the diff. I think mookaloid gets my jist and has confermed my thoughts.
Thanks for your replies
