Removing Bolts from Drive Shafts
mike smith1 - 19/8/07 at 11:55 AM
Can someone please tell me the best way to remove the torx bolts that hold the drive shafts to the diff flange,i have broken 3 normal torx sockets and 3 impact grade ones, i have got the majority out but i have 2 in onside and 1 in the other that just wont budge, i have had warmed them up with the blowtorch etc and they just wont budge.
Cheers Mike
[Edited on 19/8/07 by mike smith1]
chris_harris_ - 19/8/07 at 12:09 PM
Sounds like you've doen quite well so far. Looks like the last ones will have to be attacked with an angle grinder, cut the head of and they should come out no problem, Replace them all with 12.9 grade capheads after, much easier.
jollygreengiant - 19/8/07 at 12:10 PM
Normally I've been able to get a good pair of mole grips on a head and just get enough leverage to start it turning. after that its use a torx bit.
First step as always is to get ALL the dirt out of the torx recess, then fit torx and give it a couple of good hits with a hammer to break any seal on the the threads. Get a good long extension and breaker bar, then with a reaction lever through two of the wheel bolts to stop the whole assembly turning apply pressure and undo bolts. Never broken a torx bit since doing the above way.
Hope this helps.
SALAD - 19/8/07 at 12:26 PM
Also apply lots of penetrating fluid, 'miracle tool' is my prefered choice, but other products are available. Leave it a while to do it's job then they should be easy.
