HI, I've tried to search for info on how to rebuild/set up a 3.62 lsd with no luck.
From empty case up.
Has anyone done one or can anyone supply details how to do it pls?
I think it would be appriciated by more than just me if the info was out there. I have read in other posts that the haynes does not go into much
detail.
Is there anywhere on the tinternet?
There is a pdf file that I have that takes you through it but it says scorpio, some of the principles may be the same but worth a look anyway!
Cannot attach the bloody thing, can anyone tell me how to?
or u2u me your email addy and i'll send it
Mike
[Edited on 21/8/07 by mike smith1]
I may be wrong, but thought the older haynes had this sort of info in?
My pink v6 sierra haynes (2.3, 2.8 & 2.9) has complete strip and rebuild of the type9. Will check it tonight if I remember..
Ned.
Ray.
