Hi everyone,
I'm refurbishing a kitten chassis & need a set of rubber bushes and ball joints.
Is there a reliant specialist on the web who might help?
Is there a URL or contact for a firm who would supply bushes by measurement?
Would one of the polybush suppliers try to match measurements?
Front sus. ball joints - is there a URL or contact for a supplier with measurements. TREs will probably be classic mini but upper & lower
I'll have to bodge something I think - it's not too bad, I'll be making the wishbones new anyway...
Or if there's a restoration supplier with everything, that would be fine.
cheers
Bob
try owner's club they will know where to get bits.
Caber
Bob
Couple to kick off with. Never used them, so can't vouch for them.
http://www.reliantpartsworld.co.uk/
http://www.reliantownersclub.co.uk/enter.html
Simon
my local engineering place can make suspension bushes from nylon, so PU shouldn't be a problem. contact one local to you, and they should sort you out with bushes
forget his name, but what about contacting the chap on here with the kitten van with a bike engine in the back, he also runs a garage iirc so probably
knows...
Ned.
try foggy
IIRC the Kitten used Triumph front suspension. Bushes should be easy to get from Rimmers etc
I was browsing yesterday the McMaster Carr online catalog, and found the "Plastic Flanged Sleeve Bearings bushings", but these are listed on
Delrin, Nylon and Teflon.
I understand that these plastics are a little bit too hard.
http://www.mcmaster.com/
Page 1073.
They are cheap though...
Thanks everyone,
actually foggy has very few reliant bits in his van....... but good idea, he's probably a good source of info.
I've bought a full set of mini brakes for it & measured up the bushes & ball joints today.
I've tried various reliant hits on google but they've all turned out to be chimeras so far - I'll try the URLs listed, Ta
Bob
update - rimmer bros, completely useless for me.- can only supply known parts for known applications (not reliant). can't work from
dimensions.
Now trying local accessory shops......
Bob
if it is triumph you could try canley classics
www.canleyclassics.com
