Just a quick query:
Which parts rotate relative to each other in the typical '7' suspension bush consisting of a stainless steel tube inside a pair of 'top
hat' plastic bushes?
I'm assuming that you do the bolts up tight so the stainless tube is clamped in the bracket, and the bushes are a tight fit in the wishbones.
That way the movement occurs between the bushes and the tube (or do the bushes just twist?).
Am I right? Also, is any form of lubrication normally used?
Regards, Ian
I'm using steelsleeve rubber bushes from a peugot 205.
The inner steel bush will be clamped between the bracket.
There is no lubrication needed. I would use grease to fit the bolt just to protection againt rust.
It's important that you tighten them as the car is on his wheels in driving position! Or else the bush will be "overturned" and will
wear out quickly
grtz
[Edited on 3/9/07 by t.j.]
Ian
You have it correct, it is essential that the movement is betwween the bushes & the inner tube, otherwise bits will wear out very quickly.
I used a bit of copper slip to help ease the bushes in.....
You should not use an Oil based greese as this distroys some types of bush, If you go to a push bike shop you can bye a 100% silicon grease for a couple of quid and its perfect.
t.j. What are the dimensions of the bushes you are using? 12mm id?
