Anyone know where I can buy just the oil seals for the rear hub carriers. I have removed my hub from the drive shafts and found they are corroded and split, so I was going to buy new ones, but the bearings and races look ok, however my local motor factors only do a kit with the lot in.
Try a bearing distributor - look in Yellow Pages. If there is one near you BRT Bearings are most likely to know the part number for a car application, others will be able to get the part number if you have dimensions.
No that's a high vacuum specialist!!
