oval wish bone steel
Mr Whippy - 26/11/07 at 04:26 PM
hi
has anyone found a supplier of oval section metal rather than round tube for making wishbones as I have some to make now and these are biggies.
ta
D Beddows - 26/11/07 at 04:41 PM
Ralt
worX - 26/11/07 at 05:02 PM
You could also U2U Nitram38, I think he's made his 'bones using an elliptical shape...
caber - 26/11/07 at 08:42 PM
tons parked outside your local supermarket
round tube and a long press bed, make sure the weld on the tube is at the bottom before you press it
mine came as offcuts from a rather grander project that is now sadly RIP
Caber
Triton - 26/11/07 at 09:19 PM
Try any steel stock holder and ask for flat oval tubing..or ikea as they seem to use it for 'puta desks
procomp - 27/11/07 at 07:59 AM
Hi if it's the STD stuff that most manufacturers use it's technical name is flat sided oval commonly referred to as furniture tubing .
However if you are after the proper stuff go direct to SPA as they supplie most of it to the others.
Cheers Matt
[Edited on 28/11/07 by procomp]
Mr Whippy - 27/11/07 at 07:51 PM
thanks guys I'll see how much the want for it.
Mark Allanson - 27/11/07 at 08:08 PM
Ask an engineering firm to throw some round seamless through the rollers
flak monkey - 29/11/07 at 07:41 AM
D Beddows has it right.
Ralt sell the proper CDS oval tubing for between £6 and £8 per metre. A fraction of the price that Spa want. They also sell spherical bearing housings to weld into the ends of the tubes to save you some time.
Ralt Catalogue
