Steering Wheel Fitting!
Dave Bailey - 3/2/08 at 10:01 PM
Anyone fitted a removable steering wheel to an adjustable Sierra Steering column.?
thanks
Dave B
RazMan - 3/2/08 at 10:40 PM
There are a couple of options, bolt on or weld on. Which one did you have in mind?
Dave Bailey - 3/2/08 at 11:08 PM
I thought when I tried to remove the steering wheel off my column a while back that it had some sort of spring assy that would stop me from using a weld on.
Is this wrong? I suppose a bolt on would be easier...
thanks
Dave B
worX - 3/2/08 at 11:09 PM
Yes, mine is a weld-on Wilwood one, done by my manufacturer.
I would not recommend this one though as there is a little play in the mechanism...
