Rear uprights, photos anyone please?
Hilux - 23/10/03 at 04:45 PM
Hi all,
First post and looking for advice please.
I used to own a westfield and now own a Ginetta
In an ideal world I want to convert it to IRS using sierra IRS setup.
Alternative is de dion axle.
Does anyone have pictures or posted pictures of their setups please ?
What do Locost use for the rear IRS upright?
Thanks in advance
Paul
kingr - 23/10/03 at 05:04 PM
Hilux,
I used the machined mounting plate from the original sierra semi trailing arms. I cut them off, ground them down and then borrowed a friends surface grinder to get them dead flat. I then created a box around them from 3mm steel and put all the relevant mounts onto it. They're not light, but they do look to be hard as nails. I probably massively over engineered them, but it's better than have one of your wheels ripped off.
Kingr
kingr - 23/10/03 at 05:05 PM
By the way, any chance you could cut the size of your avatar down a bit please?
Kingr
JoelP - 23/10/03 at 05:07 PM
i used the full system off the sierra. not light but at least its all lined up.
BTW 150 pixels is good for avatars...
