Just a quick question, does spring steel lose it's temper if you weld it?
I don't mean does it get upset so all you smart arses can step away from the keyboard!!!
Does it affect the spring properties?
Chris
if you weld it in summer you'll be fine.
groan spring steel is heat treated and this treatment varies depending on the application it is put to use.
So if you heat it up, then you will affect its properties in some way.
you can retemper it ofcourse but will it be the same as the original? I cannot say.
Best not to in my opinion.
Spring steels vary from 0.5% (leaf spring) to 1.0% carbon by the text book any steel over 0.4% carbon after hot work should be re-heated water
quenched and then re heated again to a lower temperature and tempered by slow cooling.
I have seen springs sucessfully cut down using a gas axe without re-heatreating but never welded.
In any case even on to a spring is trick -- what are you trying to do ?
groan
to answer your question, yes it becomes soft and losses it springyness, is that a word?
[Edited on 8/2/08 by Mr Whippy]
it's for an "blade" type adjustable anti-roll bar. I can make up a bolted fixing but it would be much easier to weld it.
Do you think it could be welded and re tempered then BT?
cheers
Chris
cheers
Chris![]()
This is the set-up I'm looking for, the spring steel acts like a solid bar when it's orientated as shown in the picture, but it can be
rotated anywhere up to 90 degrees to reduce the effectiveness of the ARB.
Brazing is an option I might look into, it might by tripe but silver soldering never looks strong enough to me!
Chris
Pre heating of the anti roll bar prior to welding may be of some use.
Ronnie
in simple terms, no you cant' weld it.
sorry
I have done it once, and only once. it broke and the car ended up in the gravel trap.
